Problem with Driver 555.58.02 on Linux
System:
  Kernel: 6.9.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    clocksource: tsc avail: hpet,acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=9bdc1bb8-710e-4a2b-a1fc-d771d79d9fb1 rw rootflags=subvol=@
    quiet resume=UUID=3de67b4e-0081-4321-8b87-d6348302d4da loglevel=3 ibt=off
  Desktop: Cinnamon v: 6.2.2 tk: GTK v: 3.24.42 wm: Muffin v: 6.2.0 tools:
    avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
    Distro: Garuda base: Arch Linux
Machine:
  Type: Desktop Mobo: ASUSTeK model: CROSSHAIR VI HERO v: Rev 1.xx
    serial: <superuser required> part-nu: SKU UEFI: American Megatrends v: 7704
    date: 12/16/2019
CPU:
  Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 4x16 MiB
  Speed (MHz): avg: 2259 high: 3800 min/max: 2200/4672 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
    3: 2034 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
    12: 2198 13: 3800 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200
    20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 182399
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  Vulnerabilities: <filter>
Graphics:
  Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
    v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    (as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: DVI-D-1,HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2
    bus-ID: 0b:00.0 chip-ID: 10de:1b81 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
    loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x1080 s-dpi: 92 s-size: 1590x301mm (62.60x11.85")
    s-diag: 1618mm (63.71")
  Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled pos: primary,center
    model: BenQ GL2450H serial: <filter> built: 2015 res: 1920x1080 hz: 60
    dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
    model: Dell SE2422H serial: <filter> built: 2022 res: 1920x1080 hz: 60
    dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
  Monitor-3: HDMI-A-2 mapped: HDMI-1 note: disabled pos: left
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1070 driver: nvidia v: 555.58.02
    device-ID: 10de:1b81 surfaces: xcb,xlib
Audio:
  Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 0b:00.1 chip-ID: 10de:10f0 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api with: aoss
    type: oss-emulator tools: N/A
  Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
  Server-2: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Network:
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
    chip-ID: 8086:1539 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Info: services: NetworkManager,systemd-timesyncd
Drives:
  Local Storage: total: 7.28 TiB used: 871 GiB (11.7%)
  SMART Message: Unable to run smartctl. Root privileges required.
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
    Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QGXA7
    temp: 34.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA723020ALA641
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A840 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD10EFRX-68PJCN0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A82 scheme: MBR
  ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD10EADS-00M2B0 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A01
    scheme: MBR
  ID-6: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 860 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-7: /dev/sdf maj-min: 8:80 vendor: SanDisk model: SSD PLUS 1000GB
    size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 00RL scheme: MBR
Partition:
  ID-1: / raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
    used: 871 GiB (97.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 584 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
  ID-4: /var/log raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
  ID-5: /var/tmp raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
Swap:
  Kernel: swappiness: 133 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 31.27 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 34.39 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3
Sensors:
  System Temperatures: cpu: 52.0 C mobo: 27.0 C gpu: nvidia temp: 55 C
  Fan Speeds (rpm): cpu: 1227 case-1: 0 case-2: 1032 case-3: 0 gpu: nvidia
    fan: 0%
  Power: 12v: 12.29 5v: N/A 3.3v: N/A vbat: 3.16
Info:
  Memory: total: 32 GiB available: 31.27 GiB used: 8.44 GiB (27.0%)
  Processes: 515 Power: uptime: 1h 18m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.46 GiB services: csd-power,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 2142 libs: 619 tools: paru,yay Compilers:
    clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
    running-in: gnome-terminal inxi: 3.3.35
Garuda (2.6.26-1):
  System install date:     2024-01-20
  Last full system update: 2024-07-03
  Is partially upgraded:   No
  Relevant software:       snapper NetworkManager dracut nvidia-dkms
  Windows dual boot:       Probably (Run as root to verify)
  Failed units:            vmware.service
I’m on Garuda Linux based on Arch. I have three Monitors. Two connected with HDMI and one via DVI. The monitor on DVI is a black screen.
I attach the NVIDIA bug report.
nvidia-bug-report.log.gz (2.8 MB)
Same here with Arch Linux. Had to roll back.
Same here with Manjaro. Second monitor connected with DVI->VGA adapter.
Same problem here using Nobara 40, the second monitor does not turn on with a GTX-970
Same here with Fedora. how long will it take approximately for NVIDIA to fix this? I’ve given feedback on the 555 release and feedback discussion post but it has almost been a month since this issue occurred and hasn’t been fixed for me yet.
this problem has been going on for me for over a month and i have written an email, and posted twice on the linux nvidia driver forum but no one has responded to any of my complaints. its utterly frustrating that neither nvidia or anyone else seems to get back to you or acknowledge your problems on your OS and/or driver version.
Can you please give 560.35.03 a try? From the release notes:
Fixed a bug, introduced in 555.58, where some DVI outputs would not work with HDMI monitors.
I use a rolling release distro (Fedora 40) and 560 has not been available yet for me to upgrade to. it there a way for me to manually update to 560 somehow?
Fedora 40 isn’t a rolling release distro. You could try to search the copr for a NVIDIA repo.
