Problem with HDMI on Ubuntu 22.04 / Asus A15 TUF566IU, transfer SSD to this laptop from MSI
HDMI not detect monitor.
nvidia-bug-report.log.gz (426.8 KB)
Seems the HDMI port on your laptop is driven by the primary AMD gpu, the nvidia gpu drives the display port. All external connectors show “disconnected” on both gpus. Already tried a different cable? Otherwise, you could try to switch to the HWE kernel of ubuntu 22.04 to check if there’s a bug with the amdgpu driver.
Thank you. Problem is in cable, because I use VGA to HDMI adapter cable. On simple HDMI cable all works. But this is strange… on old laptop (msi 14b4mw) this cable works well with same Ubuntu setup.
HDMI2VGA must be an active converter, maybe it doesn’t get enough power on the new notebook to run.
Thank you very much :) This is exactly what the problem was.
