I am having some problems with jetson orin and need help.
When I connected the screen, I found that the orin motherboard could not be turned on, and the system was restarted repeatedly. When I unplugged the screen, I found that the motherboard started normally and could be accessed remotely. The screen and wire were normal. Can you help me analyze it
Hello, I read this post and found that this is not the problem. My emmc and orin’s jetpack versions are both 5.1.1. My question is why I can’t boot normally when I connect the display screen, and I can boot normally when I do not connect the display screen. But I don’t know what is the condition that triggers this problem
Yes, this is a different motherboard problem, I first look at the UEFI version, thank you very much. There is also a question, I do not use SDK burn, UEFI version will change
My doubt is whether UEFI will be automatically updated, because in fact, there is no UEFI corresponding to jetpack 5.1.2 in my file burned. I will check it, thank you again
Hello, I have a piece of orin motherboard restarted repeatedly, using SDK to brush the machine also failed, you look at this log, can you find the problem 反复重启.txt (559.9 KB)
