I’m trying to get ISER to work under Ubuntu 15.10. I was able to get RDMA set up and functioning ( https://community.mellanox.com/s/article/howto-setup-rdma-connection-using-inbox-driver--rhel--ubuntu-x ), but I can’t get either or TGT to work.
When I try LIO ( https://community.mellanox.com/s/article/howto-configure-lio-enabled-with-iser-for-ubuntu-14-04-inbox-driver ), the ib_sert module won’t load. When I run the “insmod”, I get the following:
insmod: ERROR: could not insert module /lib/modules/4.2.0-16-generic/kernel/drivers/infiniband/ulp/isert/ib_isert.ko: Unknown symbol in module
When I try TGT ( https://community.mellanox.com/s/article/howto-configure-tgt-enabled-with-iser-transport-for-ubuntu ), I can’t change the transport from TCP to ISER.
Any help would be appreciated.
EDIT: I installed the OFED 3.2 drivers and tools.
Sophie,
You’re saying that Ubuntu 15.10 isn’t a supported platform? The MLNX_OFED download page disagrees with you.
In any case, it’s not worth the effort. I expect that there’s someone out there who actually supports their high performance interconnect on a current OS release … just not Mellanox.
Hi Peter,
This is expected if the following configuration is not in place, please see below:
In the RN, and confirmed by engineering, only following OS supported (without extensions) (ie: 14.04.02,.03,.04):
• RHEL 7.0/7.1/7.2
• SLES12/12.1
• Ubuntu14.04, Ubuntu15.04
The right combination is to choose OS from the list with distro kernel and install mlnx_ofed.
You can also use upstream kernel (the target core is more stable there) instead of mlnx_ofed in order to run isert.
So to clarify:
- Either Ubuntu 14.04 or 15.04 (no extension) + Mellanox OFED driver.
or
- Ubuntu 14.04 or 15.04, upstream Kernel with INBOX driver.
Thank you,
Sophie.
Hi Peter,
UB15.10 is supported in MLNX_OFED and so does iSER.
As Sopie mentioned there is a need to add support to iSER target (ib_isert) for this platform as mentioned in the release notes.
TGT is a user space target and I’ve tried it (on MLNX_OFED-3.3 rc - but it shouldn’t matter) and it works for me.
please supply more info on the TGT failures (+ all the steps you made) and I’ll try to help.
thanks,
Max.
Storage Team.
