I put in a sound card from a common brand that I found in a store, until then the Jetson Orin Nano was working perfectly, but after testing the sound card and turning off the device safely, it stopped working. Right now, when I turn the card on and connect it to a monitor, first I get the Nvidia interface, a few seconds pass and it turns off and then there is no signal on the monitor. I have checked the BIOS and everything is correct according to a technician from my country, I sent the reset to default in everything I could, I loaded the jetpack again to the SD, and I have checked from the BIOS that the jetson is reading the files from the sd, but none of those options have helped me solve the problem. What can I do? Does anyone know why this problem occurred? Does anyone know how to solve it?
Sorry for the late response.
