Programatically adding an articulation root
I’m building my robot programatically and would like to add an articulation root to its base. How is this done programatically? Or does this not make sense for some reason?
-Dan
yes, you should be able to mark it in python code.
Articulation root API is expected either on a parent prim that has the whole rigid body → joints graph (this is typical) or directly on a body or a joint depending if you want to have floating or fixed articulation. The rules are described here:
https://openusd.org/release/api/class_usd_physics_articulation_root_a_p_i.html#details
From python you should just call UsdPhysics.ArticulationRootAPI.Apply(prim)
Regards,
Ales
Awesome, thank you, I was really stuck on this!
