Hi there, I am running into some issues with an extension that I have written for Omniverse where it calls a workflow that runs a simulation.
I can run an command like this in a python script (same file location as the extension etc etc) and it run the workflow perfectly:
output = subprocess.run(cmd, capture_output=True, text=True)
print(f'stdout:\n\n{output.stdout}\n\n')
print(f'stderr:\n\n{output.stderr}\n\n')
whereas when I run this command from inside the extension (say a button in omniverse that exectues a function that runs the same line of code) it throws an error:
File "/usr/bin/cwltool", line 33, in <module>
sys.exit(load_entry_point('cwltool==3.1.20220224085855', 'console_scripts', 'cwltool')())
File "/usr/bin/cwltool", line 25, in importlib_load_entry_point
return next(matches).load()
File "/usr/lib/python3/dist-packages/importlib_metadata/__init__.py", line 168, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/usr/lib/python3/dist-packages/cwltool/main.py", line 47, in <module>
from . import CWL_CONTENT_TYPES, workflow
File "/usr/lib/python3/dist-packages/cwltool/workflow.py", line 22, in <module>
from . import command_line_tool, context, procgenerator
File "/usr/lib/python3/dist-packages/cwltool/command_line_tool.py", line 50, in <module>
from .docker import DockerCommandLineJob
File "/usr/lib/python3/dist-packages/cwltool/docker.py", line 22, in <module>
from .job import ContainerCommandLineJob
File "/usr/lib/python3/dist-packages/cwltool/job.py", line 36, in <module>
import psutil
File "/usr/lib/python3/dist-packages/psutil/__init__.py", line 102, in <module>
from . import _pslinux as _psplatform
File "/usr/lib/python3/dist-packages/psutil/_pslinux.py", line 26, in <module>
from . import _psutil_linux as cext
ImportError: cannot import name '_psutil_linux' from 'psutil' (/usr/lib/python3/dist-packages/psutil/__init__.py)
Looking at it I wonder if it is something to do with the python environment that omniverse is using doesn’t match up with the environment I have things installed in on my machine? It used to work using both this method and using os.sys() but after installing a newer version of python it seems to have broken…
Anyone got any ideas?
