I have a Dell 7710 w/ a Quadro M3000M. I run a external monitor over HDMI. I recently tried to move to NVIDIA drivers. After an install via sudo apt install nvidia-driver-470, the monitor worked fine, but the laptop screen did not.
I then purged this package install, and tried to install 470.94 via the .run installer, same behavior.
kernel is 5.4.0-96-generic
Best I can tell, the driver isn’t detecting the laptop screen at all.
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00*+
1680x1050 59.95
1440x900 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1280x720 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
640x480 75.00 59.94
DP-5 disconnected (normal left inverted right x axis y axis)
DP-6 disconnected (normal left inverted right x axis y axis)
nvidia-bug-report.log.gz (482.7 KB)
nvidia-installer.log (33.3 KB)
