I just modified the code of deepstream_parallel_infer_app.cpp in order to save original images for each stream, which I can mark some info on it for callback。Also I modified the msgconv code to relate with the frame. But I found the duplicated message from the Kafka. And I found little time different with the message timestamp and frame timestamp.
I want to know why the messages are duplicated?
if possible, how to transfer the correct frame timestamp to message, which I can link the message with the correct frame image.
Here are the update save img code and msgconv code as below:
From the snapshoot of image savings, we also can find that the fps are only 15 (but it should be 25fps in camera setting).
And the frame 0 was missing in source_id 0, but can be found in source_id 1.
This is actually a feature of Kafka. It is usually caused by producer retries.
You can get more answers and solutions here or here
I think you need to increase the time precision to milliseconds or microseconds to distinguish each batch
In addition, did you set the attach-sys-ts property of nvstreammux to false?
If set to TRUE, system timestamp will be attached as ntp timestamp. If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached.
• DeepStream Version
• TensorRT Version
• The pipeline being used
Please make sure the camera outputs 25 images per seconds.
I guess you are using v4l2src element, For v4l2src, need to copy data from cpu to gpu in deepstream_source_bin.c. This will impact performance
In addition, using OpenCV to save images requires copying data from the GPU to the CPU, which will also affect the performance of the pipeline.
Better practice, Refer to the usage of nvds_obj_enc_process in deepstream-image-meta-test.
Why is the parameter *frame_num? Shouldn’t it be frame_num[source_id]?
