Is it possible to use part of the DDR memory area implemented in Orin as a file system?
I would like to use portion of DDR memory (about 20GB) as a temporary directory to store update files for OTA updates. Is this possible?
Best Regards,
UNA
Best Regards,
UNA
This sounds like RCM boot on jetson. We have an example to RCM boot from NFS.
AGX Orin has 32GB or 64 GB of DRAM.
I am thinking of not having the root file system on the above DRAM instead of NFS, is this possible?
Best Regards,
UNA
Try with
sudo ./flash.sh --rcm-boot your_board_config mmcblk0p1
Your approach appears to be to write the RCM boot loader to the eMMC and boot in Recovery mode instead of booting normally. Rather, I would like to have a partition for each of the eMMC and DDR RAM in the normal boot.
Best Regards,
UNA
Then it is not possible.
Hi Wayne,
The answer is that the DDR RAM area cannot have a partition like a file system. Does this mean that DDR RAM is occupied as Jetson’s work memory and cannot have a separate partition?
If there is any other reason, could you please let us know?
Best Regards,
UNA
It is just our bootflow cannot achieve your request.
