Hello, We flashed jetson agx xavier with jetpack 4.5.1 without any problem. After log-in and run apt-get update & apt-get upgrade, we are getting that error when rebooting. It does not continue to complete boot. Could you help please?
hello mert.celenk,
I assume you could recover this board by re-flashing the AGX Xavier again.
are you working with Jetson AGX Xavier Developer Kits?
please refer to Updating a Jetson Device, may I know which release version you’re going to update.
thanks
Hello, it is Jetson AGX Xavier 32GB Developer Kit. I flashed with jetpack 4.5.1 and used for a long time. We had some problems about kernel, tried to recover (you are right) by re-flashing with the same version(Not updating).
hello mert.celenk,
it’s r32.5.1 known issue, which has been fixed in the latest r32.6.1 release.
Hello JerryChang, We upgraded 32.6.1 and will use that version. Thanks for your help.
