Ran the following commands on my Jetson Nano and after restarting, I can no longer use USB connections and other functionalities
Ran the following commands on my Jetson Nano and after restarting, I can no longer use USB connections and other functionalities. Could you provide a solution?
sudo apt-get --purge remove nvidia-*
sudo apt-get --purge remove cuda-*
You can check board status by using serial console on UART.
But most likely this board requires to get flashed with sdkmanager.
