Jetson nano
I have a Jetson Nano board that has its own internal storage and was booting from it. I wanted to boot from an SD card with the operating system installed on it, so I modified the extlinux.conf file. However, now it no longer boots. I managed to enter recovery mode, but unfortunately, the keyboard and mouse do not work, so I cannot select any options. What should I do?
You could use the sdkmanager when the device is in recovery mode. First I’d connect proper mouse and keyboard to be prepared and recover the device.
kernel_flash/l4t_initrd_flash.sh you can give more arguments in the command line
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/FlashingSupport.html#using-initrd-flash-with-orin-nx-and-nano
