Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hello.
I am trying to evaluate if external PPS can be used to fsync all my cameras. In order to do this I did the dts changes and confirmed the pin from NVPPS not switching to gpio mode for providing PPS input externally - #7 by VickNV.
I see after dts changes and calling the correct mode, the NVPPS is going to gpio mode. I am using an Arduino to simulate a pps until i have the GPS in hand. I configured an out pin as a pwm and sending the signals. I tapped the wires and ground and I see the square pulse in CRO.
(P.S.: I got the cable harness connector without the wire so I did solder it myself.)
Now, I don’t see any frames coming in. I see 0 fps. So I wish to confirm if my pps is actually coming on my gpio pin. Hence can you provide a snippet code on how to read gpio in drive orin devkit from an application like camera application of driveworks. If I print the value in a loop, i can monitor if the toggle is happening.
Thanks!!
Jishnu
