Hi, I’m barely installed CUDA 8.0 on VNC when I started learning ML.
I’d like to install cuDNN for Tensorflow, but I can’t find any recommendation cuDNN for Titan Xp.
I’m using CUDA 8.0, Ubuntu14.04, driver 384.11
I’ll use TensorFlow as well. I found that TF support cuDNN v5, so I have to install v5 ?
Would be prob if I install higher version?
Can anybody help me? :0
Or can I automatically install cuDNN with some package manager?
With Thanks,
Ashley.
You will want to use whatever cuDNN your tensorflow binary is linked against, if you are doing a binary install.
Typically, recent TF versions like 1.4.x are built/linked against CUDA 8 GA2 and cuDNN 6.
If you build your own TF, you can use other combinations.
I istalled cuDNN v.7 before seeing ur comment,
Unfortunately, I cannot import tf.
There’ was “ImportError: libcudnn.so.6: cannot open shared object file: No file or directory.”
so I’ll try switch v.7 to v.6
By the way,
I’m using Anaconda (conda 4.3.30) at global directory(at server, PATH is opt/anaconda3)
Do I have to use python after “activate tensorflow” ? (I mean, virtual env.)
Thanks again,
