Recommended drivers for RTX A6000 Ada and Isaac Sim
Hi guys,
I’m am using Isaac Sim on a computer with Windows 11, Isaac Sim 2022.2.0, and, 2x NVIDIA RTX 6000 Ada Generation (Drivers: 528.49).
When I run Isaac, I get the warning:
2023-02-28 04:36:50 [703ms] [Warning] [gpu.foundation.plugin] Disabling auto-enabled Aftermath because of incompatible drivers, install recommended driver version.
According to this page the recommende drivers are 527.37 (GameReady), 527.56 (Studio). However, for my specific card, the driver versions available are R525 U3 (528.02), R525 U4 (528.24), and R525 U5 (528.49). When I forced the installation of the drivers 527.37 and 527.56 the native resolution of my monitor (4k) was not available.
Some examples are not running, as reported here and here
Is there a driver compatible with Isaac Sim and the RTX A6000 Ada?
What could be causing the mentioned examples to fail?
Thank in advance,
Juan
Hi @juanjqo , you need to follow this page for Isaac Sim driver instructions: 1. Isaac Sim Requirements — Omniverse Robotics documentation
Please update to it and let us know if you still seeing issues
@rthaker, Thank you for your reply. I updated Isaac Sim from 2022.2.0 to 2022.2.1. The examples are working well now on my PC (using driver 528.49). The recommended drivers do not work on my setup.
