Isaac sim on NVIDIA GeForce GTX 1650
Hi Everyone I am new to this forums. I have HP laptop having NVIDIA GeForce GTX 1650
robot@robot:~$ nvidia-smi
Fri Jan 17 12:23:58 2025
| NVIDIA-SMI 550.142                Driver Version: 550.142        CUDA Version: 12.4     |
|   0  NVIDIA GeForce GTX 1650        Off |   00000000:01:00.0 Off |                  N/A |
| N/A   30C    P3              6W /   30W |       4MiB /   4096MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A      2682      G   /usr/bin/gnome-shell                            1MiB |
I install related GPU drivers, Cuda toolkit, Omniverse and Isaac sim when I run Isaac sim I got following terminal output and the simulator screen is dark
I don’t know is my GPU is capable of running isaac sim how to solve this error I install all related softwares
Please use the Isaac Sim Compatibility Checker to verify that your system meets the required specifications.
@VickNV I checked the compaitabilty it show green in GPU section. only showing red in RAM because I have 8GB RAM
what I noticed is I have 800+ things cuda core and ISAAC SIM required rtx 3070 which has 6144 cuda cores
@eng.mubashir001 as noted, a GTX card is not going to support Isaac Sim as it is below the minimum requirement. my understanding is that the OV ecosystem utilizes RT cores whether it’s Isaac Sim or Composer, etc. so, if you find yourself having to use Isaac Sim for your work, it’s best to consider a hardware upgrade. RTX 3070 is listed as the minimum requirement, but the more complex/intensive simulation that you plan to do, the higher spec (such as RTX 4090 or A6000) you’d want to target to avoid any performance bottlenecks.
