Failed to run isaac-sim
2021-05-18 06:12:49 [1,372ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2021-05-18 06:12:49 [1,372ms] [Error] [carb.graphics-vulkan.plugin] vkEnumeratePhysicalDevices failed. No physical device is found.
2021-05-18 06:12:49 [1,372ms] [Error] [carb.graphics-vulkan.plugin] No physical device is found.
2021-05-18 06:12:49 [1,372ms] [Error] [gpu.foundation] carb::graphics::createInstance failed.
2021-05-18 06:12:49 [1,372ms] [Error] [omni.kit.plugin] createGpuFoundation() failed.
I ran ./_build/linux-x86_64/release/isaac-sim.sh, then I got those errors.
BTW I used gtx 1070ti.
I think your problem is similar to this post
You are using a GTX GPU (and not an RTX capable GPU) which is not supported…
Yes, as Toni said, you need a RTX GPU to run Isaac Sim.
Kindly,
Liila
