I am trying to use the follwoing to record video output of the sample app in DeepStream SDK on Jetson TX2:
gst-launch-1.0 -v ximagesrc use-damage=0 ! nvvidconv ! 'video/x-raw(memory:NVMM),alignment=(string)au,format=(string)I420,framerate=(fraction)25/1,pixel-aspect-ratio=(fraction)1/1' ! omxh264enc ! 'video/x-h264,stream-format=(string)byte-stream' ! filesink location="test.h264" -e
Unfortunately, it records everything BUT the output of the app, I haven’t looked deeply into the app, but since it’s a GST pipeline it makes sense that its output is a different source.
Any “quick-and-dirty” hacks to be able to capture this output? or record it to an output file?
