Recovery module writes to EEPROM
Hi ALL,
Can the SN be written EEPROM in Recovery mode?
Can only login to the system and then use the i2cset tool to write?
Regrads
Hi gmi2,
Yes, you can only run the command to read the EEPROM from host when your board is in force recovery state.
Please use i2cset command after boot up to modify the content in EEPROM.
You can also try if it could work if you boot it into initrd.
