Restore AGX Orin's EEPROM at 0-0050a
We accidently overwrote the EEPROM on the AGX Orin at 0-0050. Is there a way to restore this to factory settings? Apparently just re-flashing the image does not restore the EEPROM.
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
There is no official way to restore this to factory setting.
If you remember the original value in it, then you can use i2cset tool to write value back.
If you don’t remember, then may need to know which byte got corrupted on it.
We have a document here to tell the meaning of each byte
https://docs.nvidia.com/jetson/archives/r35.5.0/DeveloperGuide/HR/JetsonEepromLayout.html?highlight=eeprom
