Suspecting that there was some error with the EEPROM, I have also attached the i2c dump below. i2c_dump.txt (1.2 KB)
The board was previously successfully flashed but there were problems with reading the mac address of the Ethernet connection so I decided to flash the board again. However, this time, the flashing failed at the Parsing module EEPROM stage.
Thank you for referring me to the documentation. However, when bytes 200-220 and bytes 221-235 are examined from the i2c dump, System level part numbers and system level serial number register value is all 0. This does not seem normal and would certainly affect checksum eeprom bit255. What do you suggest here?
As for your question, no i2c related libraries were used. After the Jetpack was installed, I proceeded to installation of ROS. Ethernet cable was used to connect to a router but the connection did not show up when using ifconfig or lshw command on ubuntu.
