Ravik
September 20, 2018, 8:42am
#1
I am experincing red screen when connected to RTSP cameras, i can see some part of the video though.
https://ibb.co/iF6cHK
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 7647: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 261
TVMR: cbBeginSequence: 1179: BeginSequence 2048x1536, bVPR = 0
TVMR: LowCorner Frequency = 345000
TVMR: cbBeginSequence: 1529: DecodeBuffers = 9, pnvsi->eCodec = 4, codec = 0
TVMR: cbBeginSequence: 1600: Display Resolution : (2048x1536)
TVMR: cbBeginSequence: 1601: Display Aspect Ratio : (2048x1536)
TVMR: cbBeginSequence: 1669: ColorFormat : 5
TVMR: cbBeginSequence:1674 ColorSpace = NvColorSpace_YCbCr709_ER
TVMR: cbBeginSequence: 1809: SurfaceLayout = 3
TVMR: cbBeginSequence: 1902: NumOfSurfaces = 16, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 8 LumaBitDepth = 8, ChromaBitDepth = 8, ChromaFormat = 5
TVMR: cbBeginSequence: 1904: BeginSequence ColorPrimaries = 1, TransferCharacteristics = 1, MatrixCoefficients = 1
Allocating new output: 2048x1536 (x 16), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3464: Send OMX_EventPortSettingsChanged : nFrameWidth = 2048, nFrameHeight = 1536
** INFO: <bus_callback:123>: Pipeline running
TVMR: FrameRate = 27
TVMR: NVDEC LowCorner Freq = (310500 * 1024)
---> TVMR: Video-conferencing detected !!!!!!!!!
amycao
September 26, 2018, 9:03am
#2
I can not repro your issue, I can play well, here is my config,
[source0]
enable=1
#Type - 1=CameraCSi 2=CameraV4L2 3=URI
type=3
camera-width=1920
camera-height=1080
camera-fps-n=30
camera-fps-d=1
camera-csi-sensor-id=0
camera-v4l2-dev-node=0
uri=rtsp://10.19.225.165/media/video1
[sink0]
enable=1
#Type - 1=FakeSink 2=OverlaySink 3=EglSink 4=XvImageSink 5=File
type=3
display-id=0
offset-x=0
offset-y=0
width=0
height=0
sync=1
overlay-index=1
source-id=0
others same, i use below command:
nvgstiva-app -c configs/PGIE-FP16-CarType-CarMake-CarColor.txt
can your specify how to repro this issue?
Ravik
September 26, 2018, 10:55am
#3
The camera has 2 modes 640x480 . Deep stream is working in this one.
but no bounding boxes, it does only show labels
i am receiving this message after few mins
Debug info: gstrtspsrc.c(4810): gst_rtspsrc_loop_udp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstRTSPSrc:source:
amycao
September 27, 2018, 4:11am
#4
Is your concern is no bounding boxes, it does only show labels , right?
Ravik
September 27, 2018, 7:08am
#5
Yes we have resolved red screen issue. i think its due to large frame .
can you suggest about the bounding box ?
Hi RaviKiranK,
have you used nvgst-iva-gui APP to test it? do you see vehicle on the right plate?
You can also add a probe function in second nvgstinfer plugin’s output pad to check whether bounding box is correct?
wayne zhu
I’m facing the same problem with images of size 2448x2048, but works well when chosing EglSink instead of OverlaySink.
amycao
October 8, 2018, 7:40am
#8
Hi, Ketchup
can you paste your video with resolution 2448x2048 for test?
kayccc
October 24, 2018, 3:18am
#9
Hi Ketchup,
Have you resolved the issue or please share your video with resolution 2448x2048 for us to reproduce it.
Ketchup
October 24, 2018, 9:42am
#10
Hi amycao and kayccc, sorry for late answer.
We’ve solved the issue.
