REFLASH AGX STUCK
Before I go deeper into reading about all the SDK manager stuff, I used this repo and built myself a kernel and installed it. Then nothing showed up on my display, and so I decided to reflash. The process looks ok until it tries to flash into the board and gets a timeout. USB is attached to WSL correctly since I can confirm lsusb.
SDKM_logs_JetPack_6.2_Linux_for_Jetson_AGX_Orin_[64GB_developer_kit_version]_2025-06-12_14-56-12.zip (435.3 KB)
Attached is my logs.
Thanks in advanaced.
Hello @tacticalTALNET
As mentioned in Flashing issues using WSL - #4 by DaveYYY, the USB connection with WSL could be very unstable.
It would be better if you could try it with a physical Ubuntu machine.
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
I will double down on what @EduardoSalazar96 said: It isn’t just about USB being connected at the start of flash since USB disconnects and reconnects during flash. VMs tend to not reacquire USB for the reattach of USB unless they are set up to do so.
Ok I will try the physical ubuntu machine then.
Well, it is working now at 20% flash progress. Yeah, I noticed the SDKmanager tried to disable and enable the USB port a lot.
Thank you guys.
