Reflection in Optix Prime
Let’s answer this from bottom to top.
My idea was to get the X,Y and Z coordinates from my hit points and generate rays towards the reflected direction. Is there a function to get these parameters? If so please guide me to it.
In a ray tracer there are two ways to get the hit surface position:
  • Use the standard float3 hitPosition = ray.orign + tIntersectionDistance * ray.direction line formula in world space, or
  • calculate the hit position in object space with the vertex positions and barycentric coordinates and transform it into world space.
Most ray tracing examples use the first method.
I am trying to make a simple reflection program
If you talk about specular reflections, the formula calculating the new outgoing direction from an incoming direction and the surface normal at the hit point is really simple. The normal doesn’t even need to be in the same hemisphere as the rays.
Search for reflect inside the OptiX SDK header (*.h) and CUDA source (*.cu) files.
In OptiX 6.5.0 it’s defined in OptiX SDK 6.5.0\include\optixu\optixu_math_namespace.h
In OptiX 7.2.0 it’s defined in OptiX SDK 7.2.0\SDK\sutil\vec_math.h
using Optix Prime from Optix 6.5.
I would generally not recommend using OptiX 6.5.0 or the OptiX Prime API for new projects. The latter API doesn’t support the hardware functionality on the RTX boards and has been discontinued with OptiX 7, which in turn uses a much more modern API than any previous OptiX version.
There are optixRaycasting examples inside later SDKs which use the full OptiX API (not Prime) for ray-triangle intersection testing if you need only that. This is more flexible and will be faster on RTX boards.
I shoot rays from a spot within a cube model that I load into the program as a .obj file.
There is no need to load a cube model from a file for that. You could simply define the 12 triangles required for that manually. E.g. something like this: https://github.com/NVIDIA/OptiX_Apps/blob/master/apps/intro_runtime/src/Box.cpp
This defines the front faces on the outside (counter-clockwise winding in a right-handed coordinate system).
Doesn’t matter for specular reflections.
If you’re planning to use different models in the future, then OK, but if this is about specular reflections connecting singular points, that whole idea won’t work anyway.
I want to bounce the rays within the cube and see if the reflected rays would intersect with a certain spot (which is also set to be within the cube).
If you mean your ray origin and that certain spot inside the cube volume are points, means infinitely small, with no area (a “singular” point) this method will not work at all. You would need actual geometry to hit something randomly inside a ray tracer.
With specular reflections there is zero probability to hit a point in space exactly when randomly sampling the ray directions. The integral over the specular distribution is a Dirac, means the probability is zero everywhere except for the single case where the points actually connect.
Or in other words, there is exactly only one direction which will connect two points in space for each specular reflection.
On the other hand, inside a perfectly reflecting cube, there are infinitely many specular paths connecting two points due to infinitely many reflections being possible on all six surrounding walls.
Now the fun part. These initial directions of the specular connecting paths inside a perfectly mirroring cube can be calculated directly, without the need for any ray tracer!
For that you would only need to mirror the position of the “spot” at the faces of the initial cube and then the mirrored cubes, and repeat…
Your initial cube is 1x1x1, the first mirror operations generates one layer of cubes around that giving a total of 3x3x3 cubes, then 5x5x5, and so on. That can go on indefinitely, means with each layer of cubes, the mirrored spot positions get farther away from your ray origin in the center cube.
Each initial outgoing ray direction of these paths would then simply be this formula:
For every spot coordinate in any of the mirrored cubes: ray.direction = normalize(spot_mirrored - ray.origin);.
Now if you meant diffuse or glossy reflections, then forget that specular special case above.
That would work similarly to a path tracer where your spot can be thought of as a light and then the connecting paths could be done like in a unidirectional path tracer with direct lighting (next event estimation) for example
I’m not going to explain light transport algorithms here. You’ll find these in literature and ray tracing example everywhere. Even in my own examples:
OptiX 5/6: https://github.com/nvpro-samples/optix_advanced_samples/tree/master/src/optixIntroduction
OptiX 7: https://github.com/NVIDIA/OptiX_Apps
