I want to change the functions of UART9_TX, UART9_RX, UART10_TX and UART10_RX by modifying the registers in Ubuntu. But I cannot find the addresses for these registers in the technical reference manual. Can you provide the addresses and bit fields?
We configure these pins as UARTs on our custom board. During boot these ports will output what is shown on the debug port, which is undesired. So we want to configure these pins as GPIOs during boot and then as UARTs after entering the system.
Please use pinmux spreadsheet to configure those pins as UART.
The UARTs enabled in UEFI DTB will be used for console output.
You can either keep UEFI and kernel DTB separate, or can use overlays applicable only to UEFI DTB to disable the UARTs.
By default, kernel and UEFI use the similar DTB as following(snippet from jetson-agx-thor-devkit.conf )
