Hello there,
I reinstalled my Nvidia Jetson Xavier. but I’m missing the ./flash.sh script.
I selected all tools. What I have done wrong?
Thanks a lot!
Hello there,
Thanks a lot!
Hi aumattbro,
Please use SDK Manager to uninstall you used JetPack and download again.
You also can download L4T Driver Package and Sample Root Filesystem from here: Jetson Linux R32.7.1 Release Page | NVIDIA Developer
Thank you, for your answer!
How can I select the file, he wants to download it automatically and put it in a folder.
Hi aumattbro,
Run SDK Manager, on Step 1, under the installation step numbers, click the Repair/Uninstall hyperlink to uninstall JetPack folder.
Please reference detail from: Install Jetson Software with SDK Manager :: NVIDIA SDK Manager Documentation
Thank u, i have now the ./flash on the host system, how i can change the boot order- to boot first from net "tftp/dhcp/
i change the cbo.dts
boot-order = “net”, “usb”, “nvme”, “emmc”, “sd”;
how i flash it now to my nvidia xavier?
Thanks a LOT!
Hi aumattbro,
After change cbo.dts, you need flash by manually.
Please check detail tftp boot steps from Developer Guide.
i did, what i do wrong
$ dtc -I dts -O dtb -o cbo.dtb cbo.dts
Flash cbo.dtb
$ sudo ./flash -k CPUBL-CFG -r jetson-xavier mmcblk0p1
sudo ./flash.sh -r jetson-xavier mmcblk0p1
i got this error
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Failed flashing t186ref.
Okay i have glashed it
The problem was i forgot the -emmc
sudo ./flash.sh -r jetson-xavier-emmc mmcblk0p1
But he still not start via net
Hi aumattbro,
Please reference this topic steps for TFTP boot.
And using full flash by manually.
$ sudo ./flash.sh jetson-xavier mmcblk0p1
i have an tftp server, but what i mean is:
i change my cbo.dts to this
/dts-v1/;
compatible = “nvidia,cboot-options-v1”;
boot-configuration {
/* nvme boot-order can be in “nvme:C”, “nvme:pcie@”, or “nvme” format /
tftp-server-ip = /bits/ 8 <192 168 0 1>;
dhcp-enabled;
/ remove dhcp-enabled if uncommenting static-ip configuration /
/ static-ip = /bits/ 8 <0 0 0 0>;
* ip-netmask = /bits/ 8 <255 255 255 0>;
* ip-gateway = /bits/ 8 <0 0 0 0>;
then i do dtc -I dts -O dtb -o cbo.dtb cbo.dts
after this i flash my nvidia.
after the flash, i restart my nvidia, but he still boot normality. not over net. I dotn see a DHCP Discover request anything…
i think i know my proble, i dont put a TFTP IP Adress in my cbo.dts
how i can choose, all IPs? I want he knows automatly
What IP are you asking?
The host IP or how the device gets its own IP?
