Rel36.4.3如何让uart0作为rs232,如何调试呢
你好,
目前使用rel36.4.3版本调试Orin NX的uart0作为rs232,目前我尝试在dts中添加了如下图;但是开机dmesg,没有看到serial@3110000的节点;请问我这样配置是否正确呢,麻烦指导一下,谢谢
Jetson System firmware version 36.4.3-gcid-38968081 date 2025-01-08T01:18:20+00:
00
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
bugfs initialized
TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
   0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.148-tegra (penko@xd-u22) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #4 SMP PREEMPT Thu Apr 3 17:38:00 CST 2025 ()
[    0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit Super
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x26d82f198 TPMFinalLog=0x25e3f0000 SMBIOS=0xffff0000 SMBIOS 3.0=0x26d220000 MEMATTR=0x26748a018 ESRT=0x2667cdd98 TPMEventLog=0x25e407018 RNG=0x25a970018 MEMRESERVE=0x25e40ac18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x00000002667cdd98 to 0x00000002667cddd0.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000024a000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x271306800-0x271308fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000277ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x0000000RNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
fffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000025e1b6fff]
[    0.000000]   node   0: [mem 0x000000025e1b7000-0x000000025e3fffff]
[    0.000000]   node   0: [mem 0x000000025e400000-0x000000025e40afff]
[    0.000000]   node   0: [mem 0x000000025e40b000-0x000000025e40bfff]
[    0.000000]   node   0: [mem 0x000000025e40c000-0x000000026b8effff]
[    0.000000]   node   0: [mem 0x000000026b8f0000-0x000000026d82ffff]
[    0.000000]   node   0: [mem 0x000000026d830000-0x0000000271dfffff]
[    0.000000]   node   0: [mem 0x0000000271e00000-0x0000000271ffffff]
[    0.000000]   node   0: [mem 0x0000000272000000-0x000000027259ffff]
[    0.000000]   node   0: [mem 0x0000000272f00000-0x0000000272ffffff]
[    0.000000]   node   0: [mem 0x0000000276000000-0x0000000277ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2001056
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=d781f3f0-81e3-4003-8856-55fdc6e29a08 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
[    0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 7517728K/8133248K available (19456K kernel code, 4064K rwdata, 10060K rodata, 7616K init, 529K bss, 353376K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000381] Console: colour dummy device 80x25
[    0.000390] printk: console [tty0] enabled
[    0.000449] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000457] pid_max: default: 32768 minimum: 301
[    0.000496] LSM: Security Framework initializing
[    0.000520] Yama: becoming mindful.
[    0.000539] SELinux:  Initializing.
[    0.000617] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000634] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001757] rcu: Hierarchical SRCU implementation.
[    0.003962] Tegra Revision: A01 SKU: 212 CPU Process: 0 SoC Process: 0
[    0.004235] Remapping and enabling EFI services.
[    0.005026] smp: Bringing up secondary CPUs ...
[    0.005520] Detected PIPT I-cache on CPU1
[    0.005565] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.005608] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.006070] Detected PIPT I-cache on CPU2
[    0.006081] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.006097] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.006508] Detected PIPT I-cache on CPU3
[    0.006518] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.006532] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.008975] Detected PIPT I-cache on CPU4
[    0.009001] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.009028] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.009501] Detected PIPT I-cache on CPU5
[    0.009512] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.009527] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.009582] smp: Brought up 1 node, 6 CPUs
[    0.009586] SMP: Total of 6 processors activated.
[    0.009589] CPU features: detected: 32-bit EL0 Support
[    0.009590] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.009592] CPU features: detected: Common not Private translations
[    0.009593] CPU features: detected: CRC32 instructions
[    0.009595] CPU features: detected: Data cache clean to Point of Persistence
[    0.009596] CPU features: detected: Generic authentication (architected algorithm)
[    0.009597] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.009598] CPU features: detected: LSE atomic instructions
[    0.009599] CPU features: detected: Privileged Access Never
[    0.009600] CPU features: detected: RAS Extension Support
[    0.009602] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.024205] spectre-bhb mitigation disabled by command line option
[    0.037558] CPU: All CPU(s) started at EL2
[    0.040831] devtmpfs: initialized
[    0.059528] KASLR enabled
[    0.059735] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.059765] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.064915] pinctrl core: initialized pinctrl subsystem
[    0.065989] SMBIOS 3.6.0 present.
[    0.066002] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit Super/Jetson, BIOS 36.4.3-gcid-38968081 01/08/2025
[    0.066612] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.068537] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.068671] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.068760] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.068874] audit: initializing netlink subsys (disabled)
[    0.069047] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[    0.070929] thermal_sys: Registered thermal governor 'step_wise'
[    0.070932] thermal_sys: Registered thermal governor 'user_space'
[    0.070932] thermal_sys: Registered thermal governor 'power_allocator'
[    0.074999] cpuidle: using governor menu
[    0.075212] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.075305] ASID allocator initialised with 32768 entries
[    0.077306] Serial: AMBA PL011 UART driver
[    0.088665] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.099754] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.108583] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.108587] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.108588] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.108589] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.109689] cryptd: max_cpu_qlen set to 1000
[    0.111977] ACPI: Interpreter disabled.
[    0.113177] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.113335] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.113598] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.114040] iommu: Default domain type: Translated
[    0.114046] iommu: DMA domain TLB invalidation policy: strict mode
[    0.114409] SCSI subsystem initialized
[    0.114680] vgaarb: loaded
[    0.114903] usbcore: registered new interface driver usbfs
[    0.114927] usbcore: registered new interface driver hub
[    0.114941] usbcore: registered new device driver usb
[    0.115355] pps_core: LinuxPPS API ver. 1 registered
[    0.115359] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.115368] PTP clock support registered
[    0.115437] EDAC MC: Ver: 3.0.0
[    0.116707] Registered efivars operations
[    0.117357] FPGA manager framework
[    0.117453] Advanced Linux Sound Architecture Driver Initialized.
[    0.117996] Bluetooth: Core ver 2.22
[    0.118032] NET: Registered PF_BLUETOOTH protocol family
[    0.118037] Bluetooth: HCI device and connection manager initialized
[    0.118051] Bluetooth: HCI socket layer initialized
[    0.118058] Bluetooth: L2CAP socket layer initialized
[    0.118079] Bluetooth: SCO socket layer initialized
[    0.118595] clocksource: Switched to clocksource arch_sys_counter
[    0.151444] VFS: Disk quotas dquot_6.6.0
[    0.151519] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.151765] pnp: PnP ACPI: disabled
[    0.154645] NET: Registered PF_INET protocol family
[    0.154976] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.156414] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.156513] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.156541] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.156626] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.157981] TCP: Hash tables configured (established 65536 bind 65536)
[    0.158183] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.158212] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.158441] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.158893] RPC: Registered named UNIX socket transport module.
[    0.158900] RPC: Registered udp transport module.
[    0.158900] RPC: Registered tcp transport module.
[    0.158901] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.158921] PCI: CLS 0 bytes, default 64
[    0.159204] Unpacking initramfs...
[    0.167864] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.168211] kvm [1]: IPA Size Limit: 48 bits
[    0.168252] kvm [1]: GICv3: no GICV resource entry
[    0.168260] kvm [1]: disabling GICv2 emulation
[    0.168282] kvm [1]: GIC system register CPU interface enabled
[    0.168357] kvm [1]: vgic interrupt IRQ9
[    0.168520] kvm [1]: VHE mode initialized successfully
[    0.171839] Initialise system trusted keyrings
[    0.171887] Key type blacklist registered
[    0.172020] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[    0.175597] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.176112] NFS: Registering the id_resolver key type
[    0.176159] Key type id_resolver registered
[    0.176161] Key type id_legacy registered
[    0.176221] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.176241] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.176262] ntfs: driver 2.1.32 [Flags: R/O].
[    0.176510] 9p: Installing v9fs 9p2000 file system support
[    0.177255] integrity: Platform Keyring initialized
[    0.188697] Key type asymmetric registered
[    0.188705] Asymmetric key parser 'x509' registered
[    0.188851] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.188860] io scheduler mq-deadline registered
[    0.188866] io scheduler kyber registered
[    0.199275] EINJ: ACPI disabled.
[    0.211102] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.213033] SuperH (H)SCI(F) driver initialized
[    0.213357] msm_serial: driver initialized
[    0.214176] printk: console [ttyTCU0] enabled
[    0.215115] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.215120] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.215126] arm-smmu 8000000.iommu:  stage 1 translation
[    0.215128] arm-smmu 8000000.iommu:  stage 2 translation
[    0.215130] arm-smmu 8000000.iommu:  nested translation
[    0.215136] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    0.215141] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    0.215154] arm-smmu 8000000.iommu:  Supported page sizes: 0x61311000
[    0.215158] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    0.215159] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    0.216093] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.216096] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.216098] arm-smmu 10000000.iommu:         stage 1 translation
[    0.216099] arm-smmu 10000000.iommu:         stage 2 translation
[    0.216100] arm-smmu 10000000.iommu:         nested translation
[    0.216103] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    0.216104] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    0.216108] arm-smmu 10000000.iommu:         Supported page sizes: 0x61311000
[    0.216110] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.216111] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.216459] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.216461] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.216463] arm-smmu 12000000.iommu:         stage 1 translation
[    0.216463] arm-smmu 12000000.iommu:         stage 2 translation
[    0.216465] arm-smmu 12000000.iommu:         nested translation
[    0.216467] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    0.216469] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    0.216478] arm-smmu 12000000.iommu:         Supported page sizes: 0x61311000
[    0.216479] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.216481] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.223635] loop: module loaded
[    0.224644] megasas: 07.717.02.00-rc1
[    0.228763] tun: Universal TUN/TAP device driver, 1.6
[    0.229345] thunder_xcv, ver 1.0
[    0.229366] thunder_bgx, ver 1.0
[    0.229397] nicpf, ver 1.0
[    0.230169] hclge is initializing
[    0.230206] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.230214] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.230259] e1000: Intel(R) PRO/1000 Network Driver
[    0.230267] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.230293] e1000e: Intel(R) PRO/1000 Network Driver
[    0.230298] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.230321] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.230327] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.230341] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.230347] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.230561] sky2: driver version 1.30
[    0.231223] VFIO - User Level meta-driver version: 0.3
[    0.232831] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.232840] ehci-pci: EHCI PCI platform driver
[    0.232863] ehci-platform: EHCI generic platform driver
[    0.232940] ehci-orion: EHCI orion driver
[    0.233008] ehci-exynos: EHCI Exynos driver
[    0.233064] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.233083] ohci-pci: OHCI PCI platform driver
[    0.233107] ohci-platform: OHCI generic platform driver
[    0.233174] ohci-exynos: OHCI Exynos driver
[    0.233589] usbcore: registered new interface driver usb-storage
[    0.235369] i2c_dev: i2c /dev entries driver
[    0.236587] pps pps0: new PPS source ktimer
[    0.236600] pps pps0: ktimer PPS source registered
[    0.236609] pps_ldisc: PPS line discipline registered
[    0.238649] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.240602] sdhci: Secure Digital Host Controller Interface driver
[    0.240608] sdhci: Copyright(c) Pierre Ossman
[    0.241041] Synopsys Designware Multimedia Card Interface Driver
[    0.241621] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.242687] ledtrig-cpu: registered to indicate activity on CPUs
[    0.243617] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.244155] tegra-bpmp bpmp: Adding to iommu group 0
[    0.245495] tegra-bpmp bpmp: firmware: dc3fd3cac60f9b918e11-da583751bbf
[    0.411688] Freeing initrd memory: 15488K
[    2.283390] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    2.283430] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    2.283437] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    2.283640] hid: raw HID events driver (C) Jiri Kosina
[    2.283980] usbcore: registered new interface driver usbhid
[    2.283986] usbhid: USB HID core driver
[    2.287503] optee: probing for conduit method.
[    2.287553] optee: revision 4.2 (d78bc5fa)
[    2.346070] optee: dynamic shared memory is enabled
[    2.346328] optee: initialized driver
[    2.348315] usbcore: registered new interface driver snd-usb-audio
[    2.349802] NET: Registered PF_PACKET protocol family
[    2.350559] Bluetooth: RFCOMM TTY layer initialized
[    2.350638] Bluetooth: RFCOMM socket layer initialized
[    2.350652] Bluetooth: RFCOMM ver 1.11
[    2.350878] 9pnet: Installing 9P2000 support
[    2.350983] Key type dns_resolver registered
[    2.351579] printk: console [tty0]: printing thread started
[    2.351658] printk: console [ttyTCU0]: printing thread started
[    2.351739] Loading compiled-in X.509 certificates
[    2.354843] Loaded X.509 cert 'Build time autogenerated kernel key: 4bf7be77a93af81a45ae653a43c6808f547f2362'
[    2.396500] simple-framebuffer chosen:framebuffer: framebuffer at 0x27de00000, 0x800000 bytes
[    2.396525] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1280x1024x32, linelength=8192
[    2.403645] Console: switching to colour frame buffer device 160x64
[    2.405409] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[    2.406195] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    2.407425] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    2.408623] serial-tegra 3100000.serial: RX in PIO mode
[    2.408629] serial-tegra 3100000.serial: TX in PIO mode
[    2.408686] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    2.409298] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[    2.412005] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.412018] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.412659] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    2.418786] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    2.421625] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    2.423818] tegra-i2c c240000.i2c: Adding to iommu group 1
[    2.425525] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    2.426079] tegra-i2c c250000.i2c: Adding to iommu group 1
[    2.447045] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1985000 KHz, changing to: 1984000 KHz
[    2.448765] tegra-xusb 3610000.usb: Adding to iommu group 2
[    2.463252] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    2.463259] tegra-xusb 3610000.usb: xHCI Host Controller
[    2.463269] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    2.464005] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    2.464021] tegra-xusb 3610000.usb: irq 123, io mem 0x03610000
[    2.464132] tegra-xusb 3610000.usb: xHCI Host Controller
[    2.464136] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    2.464140] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    2.464345] hub 1-0:1.0: USB hub found
[    2.464360] hub 1-0:1.0: 4 ports detected
[    2.464615] hub 2-0:1.0: USB hub found
[    2.464626] hub 2-0:1.0: 4 ports detected
[    2.466036] irq: IRQ227: trimming hierarchy from :bus@0:pmc@c360000
[    2.466084] irq: IRQ228: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    2.466143] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.504379] ALSA device list:
[    2.504383]   No soundcards found.
[    2.515707] Freeing unused kernel memory: 7616K
[    2.515781] Run /init as init process
[    2.527604] Checking overlayfs setting...
[    2.536379] Overlayfs is disabled...
[    2.541647] Root device found: PARTUUID=d781f3f0-81e3-4003-8856-55fdc6e29a08
[    2.802587] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    2.961821] hub 1-2:1.0: USB hub found
[    2.962294] hub 1-2:1.0: 4 ports detected
[    3.086770] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[    3.112955] hub 2-1:1.0: USB hub found
[    3.113297] hub 2-1:1.0: 4 ports detected
[    3.686588] usb 1-2.4: new high-speed USB device number 3 using tegra-xusb
[    3.840441] hub 1-2.4:1.0: USB hub found
[    3.840920] hub 1-2.4:1.0: 4 ports detected
[    3.918942] usb 2-1.1: new SuperSpeed USB device number 3 using tegra-xusb
[    4.026723] usb 2-1.4: new SuperSpeed USB device number 4 using tegra-xusb
[    4.057034] hub 2-1.4:1.0: USB hub found
[    4.057420] hub 2-1.4:1.0: 4 ports detected
[    4.554584] usb 1-2.4.1: new low-speed USB device number 4 using tegra-xusb
[    4.716918] input: PixArt Dell MS116 USB Optical Mouse as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.4/1-2.4.1/1-2.4.1:1.0/0003:413C:301A.0001/input/input1
[    4.716985] hid-generic 0003:413C:301A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-3610000.usb-2.4.1/input0
[    4.846605] usb 1-2.4.2: new low-speed USB device number 5 using tegra-xusb
[    5.010331] input: SIGMACHIP USB Keyboard as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.4/1-2.4.2/1-2.4.2:1.0/0003:1C4F:0002.0002/input/input2
[    5.066871] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-3610000.usb-2.4.2/input0
[    5.070723] input: SIGMACHIP USB Keyboard Consumer Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.4/1-2.4.2/1-2.4.2:1.1/0003:1C4F:0002.0003/input/input3
[    5.130935] input: SIGMACHIP USB Keyboard System Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.4/1-2.4.2/1-2.4.2:1.1/0003:1C4F:0002.0003/input/input4
[    5.130993] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-3610000.usb-2.4.2/input1
[    5.262585] usb 1-2.4.3: new high-speed USB device number 6 using tegra-xusb
[    5.414437] hub 1-2.4.3:1.0: USB hub found
[    5.414920] hub 1-2.4.3:1.0: 4 ports detected
[    5.710589] usb 1-2.4.3.3: new full-speed USB device number 7 using tegra-xusb
[    5.932007] pcie_tegra194: module verification failed: signature and/or required key missing - tainting kernel
[    5.939116] tegra194-pcie 14100000.pcie: Adding to iommu group 3
[    5.941057] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    5.941073] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    5.941079] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    5.941082] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    5.941383] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    5.941386] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    5.970839] tegra-xudc 3550000.usb: Adding to iommu group 4
[    7.048358] tegra194-pcie 14100000.pcie: Phy link never came up
[    8.049970] tegra194-pcie 14100000.pcie: Phy link never came up
[    8.050034] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    8.050039] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    8.050043] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    8.050045] pci_bus 0001:00: root bus resource [bus 00-ff]
[    8.050047] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    8.050100] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    8.050272] pci 0001:00:00.0: PME# supported from D0 D3hot
[    8.055877] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    8.055995] pcieport 0001:00:00.0: Adding to iommu group 3
[    8.056091] pcieport 0001:00:00.0: PME: Signaling with IRQ 190
[    8.056494] pcieport 0001:00:00.0: AER: enabled with IRQ 190
[    8.056760] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[    8.056845] pci 0001:00:00.0: Removing from iommu group 3
[    8.056854] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[    8.058614] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    8.060182] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    8.060193] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    8.060199] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    8.060204] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    8.060511] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    8.060513] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.166765] tegra194-pcie 14160000.pcie: Link up
[    8.169439] tegra194-pcie 14160000.pcie: Link up
[    8.169481] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.169484] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.169486] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.169489] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.169490] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.169536] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.169700] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.172559] pci 0004:01:00.0: [1987:5013] type 00 class 0x010802
[    8.172793] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    8.174621] pci 0004:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0004:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[    8.189103] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    8.189107] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    8.189192] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.189196] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    8.189277] pcieport 0004:00:00.0: Adding to iommu group 5
[    8.189352] pcieport 0004:00:00.0: PME: Signaling with IRQ 192
[    8.189645] pcieport 0004:00:00.0: AER: enabled with IRQ 192
[    8.189820] nvme 0004:01:00.0: Adding to iommu group 5
[    8.190164] nvme nvme0: pci function 0004:01:00.0
[    8.190221] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    8.190722] tegra194-pcie 141e0000.pcie: Adding to iommu group 6
[    8.191855] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[    8.191867] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[    8.191872] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    8.191875] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    8.192173] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    8.192175] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.220449] nvme nvme0: allocated 128 MiB host memory buffer.
[    8.224032] nvme nvme0: 6/0/0 default/read/poll queues
[    8.226648]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    8.772167] EXT4-fs (nvme0n1p1): recovery complete
[    8.772693] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.780602] Rootfs mounted over PARTUUID=d781f3f0-81e3-4003-8856-55fdc6e29a08
[    8.786907] Switching from initrd to actual rootfs
[    8.818264] systemd[1]: System time before build time, advancing clock.
[    8.851146] NET: Registered PF_INET6 protocol family
[    8.851569] Segment Routing with IPv6
[    8.851576] In-situ OAM (IOAM) with IPv6
[    8.864084] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.864408] systemd[1]: Detected architecture arm64.
[    8.870881] systemd[1]: Hostname set to <nvidia-desktop>.
[    8.875893] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[    8.875909] systemd[1]: Set hardware watchdog to 2min.
[    9.009516] systemd[1]: /lib/systemd/system/snapd.service:23: Unknown key name 'RestartMode' in section 'Service', ignoring.
[    9.015263] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.018059] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.053060] systemd[1]: Queued start job for default target Graphical Interface.
[    9.054430] systemd[1]: Created slice Slice /system/modprobe.
[    9.057887] systemd[1]: Created slice Slice /system/serial-getty.
[    9.060235] systemd[1]: Created slice Slice /system/systemd-fsck.
[    9.061392] systemd[1]: Created slice User and Session Slice.
[    9.062376] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    9.066752] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.067806] systemd[1]: Reached target Slice Units.
[    9.068703] systemd[1]: Reached target Mounting snaps.
[    9.069585] systemd[1]: Reached target Mounted snaps.
[    9.070471] systemd[1]: Reached target Swaps.
[    9.074400] systemd[1]: Reached target Local Verity Protected Volumes.
[    9.078176] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    9.080224] systemd[1]: Listening on LVM2 poll daemon socket.
[    9.084993] systemd[1]: Listening on RPCbind Server Activation Socket.
[    9.086206] systemd[1]: Listening on Syslog Socket.
[    9.089241] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.090230] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    9.093424] systemd[1]: Listening on Journal Audit Socket.
[    9.094441] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.097474] systemd[1]: Listening on Journal Socket.
[    9.098563] systemd[1]: Listening on udev Control Socket.
[    9.104569] systemd[1]: Listening on udev Kernel Socket.
[    9.106354] systemd[1]: Mounting Huge Pages File System...
[    9.116292] systemd[1]: Mounting POSIX Message Queue File System...
[    9.118237] systemd[1]: Mounting Kernel Debug File System...
[    9.127677] systemd[1]: Mounting Kernel Trace File System...
[    9.130310] systemd[1]: Starting Journal Service...
[    9.137535] systemd[1]: Finished Availability of block devices.
[    9.139654] systemd[1]: Starting Set the console keyboard layout...
[    9.152445] systemd[1]: Starting Create List of Static Device Nodes...
[    9.154311] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    9.168260] systemd[1]: Starting Load Kernel Module configfs...
[    9.170455] systemd[1]: Starting Load Kernel Module drm...
[    9.180200] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.182418] systemd[1]: Starting Load Kernel Module fuse...
[    9.191398] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.193485] systemd[1]: Started Nameserver information manager.
[    9.193605] fuse: init (API version 7.34)
[    9.194369] systemd[1]: Reached target Preparation for Network.
[    9.203147] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.205047] systemd[1]: Starting Load Kernel Modules...
[    9.210880] nvsciipc: loading out-of-tree module taints kernel.
[    9.211784] nvsciipc: loaded module
[    9.217798] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.218304] nvmap_page_pool_init: Total RAM pages: 1950744
[    9.218306] nvmap_page_pool_init: nvmap page pool size: 243843 pages (952 MB)
[    9.218364] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.224860] tegra-host1x 13e00000.host1x: Adding to iommu group 7
[    9.226029] host1x-context host1x-ctx.0: Adding to iommu group 8
[    9.226149] host1x-context host1x-ctx.1: Adding to iommu group 9
[    9.226254] host1x-context host1x-ctx.2: Adding to iommu group 10
[    9.226352] host1x-context host1x-ctx.3: Adding to iommu group 11
[    9.226450] host1x-context host1x-ctx.4: Adding to iommu group 12
[    9.226547] host1x-context host1x-ctx.5: Adding to iommu group 13
[    9.226673] host1x-context host1x-ctx.6: Adding to iommu group 14
[    9.226782] host1x-context host1x-ctx.7: Adding to iommu group 15
[    9.226916] host1x-context host1x-ctx.8: Adding to iommu group 16
[    9.227029] host1x-context host1x-ctx.9: Adding to iommu group 17
[    9.227132] host1x-context host1x-ctx.10: Adding to iommu group 18
[    9.227235] host1x-context host1x-ctx.11: Adding to iommu group 19
Hi PANLINQUAN,
Are you using the devkit or custom board for Orin NX?
It seems 3100000.serial has not been probed yet.
Please run the following command on your board and share extracted_proc.dts for further check.
$ sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
Why the clock used for uartb node is TEGRA234_CLK_UARTA?
使用的是custom board
extracted_proc.txt (312.3 KB)
我是看到serial@3100000中是使用这个;才使用的,这样是不对的吗?那正确应该是怎么样的呢?,另外我还看到了另外一个dts文件:tegra234-soc-overlay.dtsi定义了serial@3110000,这里有影响吗?
They are different clocks but both come from bpmp.
Please just refer to the configuration in this device tree for serial@3110000 instead of copying what serial@3100000 uses.
