Is it possible to remove the heatsink from the Jetson Xavier? I am trying to replace it with another heatsink but i can’t remove the old one.
The heatsink can be removed after remove the screw. it is difficult because there is thermal grease between TTP and heatsink. You may could try to rotate the heatsink to loose the contaction.
