I would like to install an Industrial Xavier AGX inside a very tight compartment and because using a thermal pad\Gel between heatsinks plates is less efficient than using a single heatsink, i want to prevent using thermal pad between Xavier housing and my outer housing which has much bigger metal mass.
As so, i consider removing Xavier module cover, and use the module with my designed heatsink.
Beside warranty issues, Is AGX Xavier heatsink removal is doable without any damage to the unit?
What are the possible risks?
Can i get some minimal information about the assembly of the integrated heatsink?
Thanks in advance
Udi
