Hi Team,
I am using AGX Orin devkit flashed with L4T35.2.1. I flashed L4T35.2.1 to nvme ssd instead of emmc by following the steps in developer guide.
Used the suggested flash_l4t_external.xml file and updated the num-sectors as per the ssd connected to the board. I was able to flash and board is booting from SSD.
My doubt is, Will it cause any issue if i delete and remove the files and partitions from the emmc, as i will be using only SSD to boot the board in future?
Also when i use the flash command, where does the uefi gets flashed to?
lsblk output is attached. Let me know if you need any other information.
Hi @WayneWWW,
I am facing issue with flashing now.
NVME SSD was previously flashed with bootable image. EMMC partitions are removed.
Using the same command as earlier to flash to ssd.
But ssd flashing is failed with below error,
Waiting for target to boot-up...
Timeout
Cleaning up...
