I’m working on to create a CPP-based embedded application, where I need to render frames in a GtkGL Drawing Area inside Main Gtk Window. I found nvargus api which has the ability to render frames in gtkgl drawing area (api is setEGLDisplay) also I found plenty of examples for the same inside argus/sample dir. but in every example, they are rendering frames directly from nvargus.
Do we have some example where we can render a frame in glwindow after doing some transformation? Even API’s will work or a documentation
ThankYou
