Replicator 3d coordinates
Isaac sim 5.1
I’m trying to get 3D world coordinates of a lego block using the code below, but my code breaks in world_p = camera.get_world_points_from_image_coords(np.array([[u,v]]),depth_img[j-1:j,i-1:i][0] + (4.0 - depth_img[j-1:j,i-1:i][0]) / 2 + 0.01), I’m getting this message: 2026-01-14T04:02:21Z [386,388ms] [Warning] [omni.replicator.core.scripts.utils.utils] ‘ReplicatorItem’ object has no attribute ‘get_world_points_from_image_coords’
code
import asyncio
async def test_bbox_2d_tight():
with rep.new_layer():
    BLOCK_PRIM_PATH = "/World/block_r/block_r/tn__Part1_f5/Mesh"
    BASE_PRIM_PATH = "/World/basePartz/basePartz/tn__Part1_f5/Mesh"
    ZED_CAMERA_PATH = "/World/ZED_X/base_link/ZED_X/CameraRight"
    \# Create replicator wrappers for existing prims
    block = rep.get.prim_at_path(BLOCK_PRIM_PATH)
    base = rep.get.prim_at_path(BASE_PRIM_PATH)
    \# Apply semantics to each object
    with block:
        rep.modify.semantics(\[('class', 'lego_block')\])
    with base:
        rep.modify.semantics(\[('class', 'lego_base')\])
    \# Setup camera and attach it to render product
    zed_camera = rep.get.prim_at_path(ZED_CAMERA_PATH)
    render_product = rep.create.render_product(zed_camera, resolution=(1024, 1024))
    bbox_2d_tight = rep.AnnotatorRegistry.get_annotator(
        "bounding_box_2d_tight", init_params={"semanticFilter": "\*:lego_block|lego_base"}
    bbox_2d_tight.attach(render_product)
    \# After bbox_2d_tight, add these annotators:
    depth_annotator = rep.AnnotatorRegistry.get_annotator("distance_to_image_plane")
    depth_annotator.attach(render_product)
    rgb_annotator = rep.AnnotatorRegistry.get_annotator("rgb")
    rgb_annotator.attach(render_product)
    \# After await rep.orchestrator.step_async():
    rgb_data = rgb_annotator.get_data()
    depth_data = depth_annotator.get_data()  # This is your distance_to_image_plane data
    depth_img = depth_data  # Direct use, already float32
    rgb_img = rgb_data
    data = bbox_2d_tight.get_data()
    print(data)
    bbox_data = data\['data'\]
    first_bbox = bbox_data\[0\]
    print(first_bbox)
    x0 = first_bbox\['x_min'\]
    y0 = first_bbox\['y_min'\]
    x1 = first_bbox\['x_max'\]
    y1 = first_bbox\['y_max'\]
    #目标物体中心像素坐标的计算
    u = (x0 + x1) / 2
    v = (y0 + y1) / 2
    i = (int)(u)
    j = (int)(v)
    #像素坐标到世界的转换
    world_p = camera.get_world_points_from_image_coords(np.array(\[\[u,v\]\]),depth_img\[j-1:j,i-1:i\]\[0\] + (4.0 - depth_img\[j-1:j,i-1:i\]\[0\]) / 2 + 0.01)
    print(world_p)
asyncio.ensure_future(test_bbox_2d_tight())
Hi there, the function you are trying to use is for the camera sensor, in the example you are using a replicator wrapped camera prim.
Here is an example snippet using the function:
  • /standalone_examples/api/isaacsim.sensors.camera/camera.py
is there a similar function for the replicator ?
you could you the 3d bounding box annotator data, or reading the transforms directly from USD.
