Hi everyone.
Yesterday I was working inside the DGX server when suddenly there was a power outage.
I have never touched the server, that is something that my boss manages but she is on vacation right now.
Sorry for the noob question, but I don’t want to mess it up. Pressing just the power button of the DGX it would be enough to make it work again or it would be necessary to do something else??
Thank you very much.
Hi valderas777,
To power on the DGX system, pressing the power button should do the trick.
Is this a DGX Station? If not, for instance, if it’s a DGX A100, DGX Station A100, DGX-2, or DGX-1… you should also be able to power it on using the remote management BMC - if you have access to it.
Let us know how it goes. Best regards.
Hi jbessoudo.
Yes, I pressed the button and everything worked fine, all solved.
Thank you for your reply.
Is there any way to configure a DGX Station to restart automatically after a power failure?
Thank you,
David
