Rivermax rmx_output_media_commit_chunk() return:RMX_HW_SEND_QUEUE_IS_FULL
rivermax media_sender demo: send 190X1080 50p video
When the task starts, the rmx_output_media_commit_chunk function always returns RMX_HW_SEND_QUEUE_IS_FULL for a long time at the 619th chunk of the 8th frame. What is the reason for this and how can I solve this problem?
				do {
                    uint64_t timeout = RMX_OUTPUT_DELTA_TIME;
                    if (!(chunk_num % m_set.chunks_num_per_frame_field) ||
                        ((m_set.stream_type == AUDIO_2110_30_31_STREAM) && m_send_data[stream].first_send) ||
                        (m_set.stream_type == ANCILLARY_2110_40_STREAM)) {
                        m_send_data[stream].first_send = false;
                        timeout = send_time_ns.integer();
                        // verify windows is at least 600 nano away
                        if (likely(get_tai_time_ns() < (timeout - 600))) {
                            * When timer handler callback is not used we have a mismatch between
                            * media_sender clock (TAI) and rivermax clock (UTC).
                            * To fix this we are calling to align_to_rmax_time function to convert
                            * @time from TAI to UTC
                            timeout = align_to_rmax_time(timeout);
                        else {
                            //                            std::cout << "calling with timeout " << timeout << " delta "
                            //                                      << timeout << " now "
                            //                                      << get_tai_time_ns() << std::endl;
                            timeout = 0;
                            data.use_0_timeout++;
                    if (unlikely(!apply_schedule(m_send_data[stream].stream_id, now - start_time))) {
                        std::cout << "Failed to apply scheduled attribute change" << std::endl;
                        return;
//					//test pdf
//						status = rmx_output_media_poll_for_completion(&chunk_handle);
//						int a = 0;
                    status = rmx_output_media_commit_chunk(&chunk_handle, timeout);
					if (status == RMX_OK) {
                        data.commit_runs++;
                        break;
                    if (unlikely(status == RMX_SIGNAL)) {
                        std::cout << "Received CTRL-C, exiting..." << std::endl;
                        return;
					if (status == RMX_HW_SEND_QUEUE_IS_FULL) {
//						if (LogFlag)
//						    TXLogOut(LogLevel_KeyInfo, -1, "%s", "[run_internal] warning RMX HW send queue is full");
//						LogFlag = 0;
						printf("RMX_HW_SEND_QUEUE_IS_FULL: sendFrame[%d], chunk_num[%d] \n", dumpFrame, chunk_num);
						//std::this_thread::sleep_for(std::chrono::milliseconds(5));
						if (m_set.use_rmax_event) {
                            m_send_data[stream].event_mgr.request_notification(static_cast<rmx_stream_id>(m_send_data[stream].stream_id));
                            data.commit_waits++;
                        else {
                            data.commit_retries++;
                    else {
                        data.rmax_errors++;
                    if (status == RMX_HW_COMPLETION_ISSUE) {
                        std::cout << "got completion issue exiting" << std::endl;
						printf(" RMX_HW_COMPLETION_ISSUE \n");
						return;
                } while (status != RMX_OK);
Try to do some basic tuning first, ex, CPU isolation, affinity setting, don’t cross NUMA, etc.
The return code indicates that the send queue becomes full. Would the situation be better if the application controls the speed of the chunk commits a little slower?
