Hi!
During the analysis of a CSI 2 problem the CSI lines were probed with an osciloscope and the idle voltage of CSI_DATA1_P is different from the other CSI2 data lines. This one has 0.9V while all the other lines have 1.2V. After shutting the Orin down, we measured the resistance to GND and the diode voltage and this data line is different from the rest.
Hi, is it pin C42 of module connector? Is it on Orin devkit or your custom board? Do you have another module/carrier to verify it is related to module or carrier?
Hi Trumany,
sounds like we measured on a different connector you are refering to. We measured on the pin 13 of the J509 connector, see screenshot.
kind regards,
Martin
Edit: We only have one, maybe we are about to order a 2nd.
I’ll be on vacation the next 1.5 weeks. Any questions from your side?
So you are testing on devkit, right? Pin13 of J509 is CSI_0_D1_P pin. It has no special design on module and should be same voltage level as other CSI data pins. If you are sure it has voltage level issue and cause function failure, you can run RMA for the devkit.
Yes, we are currently using the devkit. Pin13 is definitely behaving different from the othe CSI lines. How would the RMA work? Do I need to send the devkit somewhere?
