Why does my own robot model always alert me that prim is not defined after importing isaac sim, so I cannot bind the joint? What should I do
rthaker
2
Hi @2997216828 - Is this similar kind of issue as mentioned in this forum post? Robot floating after import - #4 by rgasoto
Related topics
Topic | Replies | Views | Activity | |
Robot floating after import | 3 | 600 | April 5, 2024 | |
Beginner Help Needed with Robotic Manipulator | 0 | 13 | August 27, 2024 | |
Why does the joint fail to form a closed loop after importing the XML into Isaac Sim? | 6 | 24 | May 16, 2025 | |
Cannot create a joint between a body and itself | 3 | 1002 | March 6, 2024 | |
Gripper on the robot | 3 | 129 | October 2, 2024 | |
How can i fix Prim is not an articulation | 3 | 1046 | November 23, 2023 | |
Imported robot create joint "you cannot create a joint between a body and itself" | 0 | 47 | November 26, 2024 | |
Import self-created model in isaccsim reinforcement learning with error 'Invalid prim' null prim' | 1 | 574 | January 10, 2024 | |
Can't Configure Isaac Sim Robot Properly | 0 | 50 | October 26, 2024 | |
Robot model in Isaac Sim falls apart | 3 | 1380 | March 24, 2022 |
