Are there any ways to edit or rebuild the ROS2 bridge to so that I can fix issues with the message Isaac publishes? I’m testing with Isaac Sim 2022.2.0 and its ability to publish class labeled information to ROS but none of the publishers send valid data.
If I make a camera that publishes instance_segmentation information and try to view it in ROS it’s in the wrong format to view them in tools like RViz or RQT. Is there a way to get the pixel color value to class_id map?
If I change the camera type to bbox_2d_loose/tight then no data is published on the topic.
If I change the camera to publish bbox_3d data then it sends message that are not properly filled out or in the correct scale.
If I try and echo the message with the new Humble bridge enabled I can’t inspect them but if I switch to the Foxy bridge I can see that it’s not filling in the data correctly and is missing the class_id which means the bounding box information is not very useful to anyone subscribing.
header:
stamp:
sec: 14
nanosec: 450000753
frame_id: carter_camera_stereo_left
detections:
- header: ####### Not filled in!
stamp:
sec: 0
nanosec: 0
frame_id: ''
results:
- hypothesis: ####### There is only a single hypothesis for all bounding boxes even though there are multiple class_id's included in the field of view.
class_id: '' ####### Not filled in!
score: 1.0
pose:
pose:
position:
x: 0.0
y: 0.0
z: 0.0
orientation:
x: 0.0
y: 0.0
z: 0.0
w: 1.0
covariance:
- 0.0 ###### all zeros
bbox:
center:
position:
x: -9.05989933013916
y: -0.7591999769210815
z: 0.7092979550361633
orientation:
x: 0.0
y: 0.0
z: 0.0
w: 1.0
size: ####### Not in the correct units of meters, but after checking it looks like "carter_warehouse_navigation.usd` is in CM but the world units are Meters.
x: 37.9998779296875
y: 24.99999237060547
z: 14.875
- header:
stamp:
sec: 0
nanosec: 1
frame_id: '' ####### Not filled in!
results: []
bbox:
center:
position: ####### Not filled in!
x: 0.0
y: 0.0
z: 0.0
orientation:
x: 5.0e-324
y: 0.0
z: 5.0e-324
w: 2.1219957915e-314
size: ####### Not filled in correctly!
x: 0.0
y: 1.0
z: 0.0
