I’m running into a ROS 2 Humble communication issue on a Jetson Orin Nano with JetPack 6.
Nodes running in separate terminal sessions inside the same Docker container cannot communicate. For example, if I start a container with docker run --network host ... and run the listener demo, and then open a second shell into that same container with docker exec and run the talker demo, the listener receives no messages.
This is not a general ROS 2 issue, as the talker and listener communicate perfectly when run in a single terminal (with one in the background). My full C++ perception pipeline also works correctly on the host OS, outside of Docker.
This seems to be a specific problem with ROS 2 DDS discovery between docker exec sessions on the Jetson platform. Has anyone else encountered this, and is there a known configuration or workaround?
Thank you. I can confirm I am running JetPack 6.0 (L4T R36.2.0). Before I go through the upgrade process, could you please confirm if the ROS 2 DDS discovery issue between docker exec sessions is a known bug in this specific version that is resolved in 6.2.1?
We are using a custom image built from the official L4T ML container for JetPack 6. Here is the complete Dockerfile that we successfully built:
Start from the NVIDIA ML container
FROM nvcr.io/nvidia/l4t-ml:r36.2.0-py3 Set environment variables for non-interactive installs and library paths
ENV DEBIAN_FRONTEND=noninteractive
ENV LD_LIBRARY_PATH=/opt/ros/humble/lib/aarch64-linux-gnu:${LD_LIBRARY_PATH} Install all system dependencies, including ROS 2 and GUI tools
RUN apt-get update && apt-get install -y --no-install-recommends
git build-essential cmake libopenblas-dev libomp-dev python3-dev python3-pip
curl software-properties-common xterm &&
add-apt-repository universe &&
curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg &&
echo “deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] http://packages.ros.org/ros2/ubuntu $(. /etc/os-release && echo $UBUNTU_CODENAME) main” | tee /etc/apt/sources.list.d/ros2.list > /dev/null &&
apt-get update &&
apt-get install -y
ros-humble-ros-base
ros-humble-rviz2
ros-humble-pcl-conversions
ros-humble-vision-msgs
ros-humble-can-msgs
ros-humble-tf2-ros
ros-humble-demo-nodes-cpp
python3-colcon-common-extensions &&
apt-get clean &&
rm -rf /var/lib/apt/lists/*
docker run -it --rm --name jetson_dev --gpus all --network host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix -v ~/ros2_ws_clean:/workspace/ros2_ws_clean -v /mnt/ssd1tb:/mnt/ssd1tb ros2-ai-env bash
Thank you for the follow-up. Let me provide a crucial clarification.
After more testing, I’ve found that communication does work if I start a single container and open multiple shells into it with docker exec.
However, the core problem remains: communication fails between two completely separate container instances that are each started with a separate docker run command.
For our project’s architecture, this multi-container communication is a critical feature, so the current failure is a significant blocker.
Could you please confirm if this failure of DDS discovery between separate docker run containers (both using --network host) is a known issue on JetPack 6? Is there a specific configuration for Docker or the DDS middleware required to enable it?
