RTX 3060 Installed Latest Nvidia Driver 470 and Went Blackscreen
I know many people have come across this problem but their solutions do not solve my problem. So I come here for help.
Just installed the latest 470 drivers on my RTX3060 card and Ubuntu 18.04 system and everytime login the computer went to blackscreen. In recovery mode, running nvidia-smi it shows the driver has been installed.nvidia-bug-report.log (756.8 KB)
Also tried other versions of drivers, same problem. Have a integrated Intel graphic card and a Nividia graphic card.
Edit: I installed using autoinstall and kernel is 5.04-generic, run modinfo nvidia I have
filename:       /lib/modules/5.4.0-89-generic/kernel/nvidia-470/nvidia.ko
firmware:       nvidia/470.74/gsp.bin
alias:          char-major-195-*
version:        470.74
supported:      external
license:        NVIDIA
srcversion:     07D207F12985B9A6E0B04CB
alias:          pci:v000010DEd*sv*sd*bc03sc02i00*
alias:          pci:v000010DEd*sv*sd*bc03sc00i00*
depends:        drm
retpoline:      Y
vermagic:       5.4.0-89-generic SMP mod_unload modversions
signat:         PKCS#7
signer:
sig_key:
sig_hashalgo:   md4
parm:           NvSwitchRegDwords:NvSwitch regkey (charp)
parm:           NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm:           NVreg_ResmanDebugLevel:int
parm:           NVreg_RmLogonRC:int
parm:           NVreg_ModifyDeviceFiles:int
parm:           NVreg_DeviceFileUID:int
parm:           NVreg_DeviceFileGID:int
parm:           NVreg_DeviceFileMode:int
parm:           NVreg_InitializeSystemMemoryAllocations:int
parm:           NVreg_UsePageAttributeTable:int
parm:           NVreg_RegisterForACPIEvents:int
parm:           NVreg_EnablePCIeGen3:int
parm:           NVreg_EnableMSI:int
parm:           NVreg_TCEBypassMode:int
parm:           NVreg_EnableStreamMemOPs:int
parm:           NVreg_RestrictProfilingToAdminUsers:int
parm:           NVreg_PreserveVideoMemoryAllocations:int
parm:           NVreg_EnableS0ixPowerManagement:int
parm:           NVreg_S0ixPowerManagementVideoMemoryThreshold:int
parm:           NVreg_DynamicPowerManagement:int
parm:           NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm:           NVreg_EnableGpuFirmware:int
parm:           NVreg_EnableUserNUMAManagement:int
parm:           NVreg_MemoryPoolSize:int
parm:           NVreg_KMallocHeapMaxSize:int
parm:           NVreg_VMallocHeapMaxSize:int
parm:           NVreg_IgnoreMMIOCheck:int
parm:           NVreg_NvLinkDisable:int
parm:           NVreg_EnablePCIERelaxedOrderingMode:int
parm:           NVreg_RegisterPCIDriver:int
parm:           NVreg_RegistryDwords:charp
parm:           NVreg_RegistryDwordsPerDevice:charp
parm:           NVreg_RmMsg:charp
parm:           NVreg_GpuBlacklist:charp
parm:           NVreg_TemporaryFilePath:charp
parm:           NVreg_ExcludedGpus:charp
parm:           rm_firmware_active:charp
The kernel that comes with ubuntu 18.04 (5.4) is too old to support your intel gpu. Please upgrade to Ubuntu 20.04 or install a 5.10 kernel manually.
You will need 4 packages
linux-headers-XX
linux-headers-XX-generic
linux-image-unsigned-XX-generic
linux-modules-XX-generic
from Index of /~kernel-ppa/mainline/v5.10.75
