Rtx 3060 not recognising internal screen on acer triton 300
Hi I installed ubuntu 18.04 on my acer predator triton 300 which has RTX 3060 card in it.
The problem I am facing is that I am unable to use an external monitor and the internal monitor at the same time.
If i select the Nouveau video drivers, it seems to not recognise the rtx 3060 and external display does not work.
On the other hand if i select the nvidia drivers (470) the external monitor works and the cards is recognised correctly but the internal screen does not work. what makes it even worst is that if i have the drivers set as nvidia drivers, I am left blind when i disconnect the external screen.
my kernel version is 5.4.0-84-generic
I have tried the usual online stuff including purging nvidia drivers and reinstalling them etc.
Any help will be much appreciated.nvidia-bug-report.log.gz (329.1 KB)
Without looking at the bug report log, I’m 99,99% sure your kernel is just too old. I’d go with at least Ubuntu 20 and kernel 5.10 or newer.
Can’t move into Ubuntu 20, a lot of the stuff I use is not compatible with ubuntu 20. the bug report was attached. I am reattaching it here .
Thank younvidia-bug-report.log.gz (329.1 KB)
Well then get a newer kernel…
Hi, I recently bought an Acer Predator Triton, 2022 model. Same with @ujjar.bhandari alot of my projects run on 18.04 and is not compatible with 20.04.
However, I am facing issues like no wifi, brightness control, sound, and trackpad not working. Is it still possible to dual boot ubuntu 18.04? And where can I find all the drivers to fix those issues?
Any input will be greatly appreciated! Thank you!
Please see this:
https://forums.developer.nvidia.com/t/ubuntu-18-04-doesnt-use-my-gpu-gtx-1650/227606/5?u=generix
Hi there,
i upgraded my kernel to 5.10, and that solved most of my issues with ubuntu 18.04. The only thing not working for me at the moment is the wifi adapter, but I am mostly wired in so not an issue for me. On the odd occasion i need to use wifi, i just use an usb adapter.
I hope this helps.
