I recently switched from the open kernel modules to the proprietary drivers due to stability issues. The installed proprietary drivers (525.89.02) fail to recognize my connected Core X eGPU.
Attached below is my output from lspci and nvidia-smi on both the proprietary and open kernel modules, as well as my nvidia-bug-report.log.gz file.
On open kernel modules:
[zurrty@framework ~]$ lspci | grep NVIDIA
04:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070 Lite Hash Rate] (rev a1)
04:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
[zurrty@framework ~]$ nvidia-smi
Wed Mar 8 16:17:01 2023
| NVIDIA-SMI 525.89.02 Driver Version: 525.89.02 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:04:00.0 Off | N/A |
| 0% 30C P8 11W / 220W | 1MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
With proprietary drivers:
No devices were found
nvidia-bug-report.log.gz (479.3 KB)
