It appears tensorflow 2.13.0 requires 11.8 and the earliest driver for the laptop GPU comes with 12.0
Does this mean I can’t yet use the RTX Laptop GPU with tensorflow 2.13.0?
Any workarounds to get this working locally …
Its for this laptop
Its for this laptop
The driver CUDA support is not what matters here. As long as the driver supports CUDA 11.8 or newer, it will be fine. You can install CUDA 11.8 toolkit with a driver for CUDA 12.0 and it will work.
from that point onward, you should be able to continue setup of TF 2.13
Thank you
Do I also need to install cudnn 8.6?
I got everything working wonderfully. Thanks for the clarification.
Does RTX 4090 Laptop GPU support CUDA ?
