Summary
After a warm reboot (systemctl reboot), the driver fails to enumerate my only display and
the screen stays black.
Never happens on a cold boot / full power-off; a full power-off is the
only reliable recovery. Present since at least driver 590.48.01 (Feb, kernel 6.19); still present
on 610.57.04 (kernel 7.2.3).
Hardware / software
- GPU: NVIDIA GeForce RTX 5090 (GB202), VBIOS 98.02.2E.40.AC, board MSI [1462:5302]
- Motherboard: ASUS ProArt X870E-CREATOR WIFI (Ryzen, AMD iGPU present but unused — single monitor on the 5090)
- Monitor: Samsung Odyssey Neo G9 57" (G95NC), 7680x2160 @ 120 Hz, single DisplayPort cable to the 5090
- Driver: nvidia-open 610.57.04 (also reproduced on 590.48.01)
- Kernel: 7.2.3 (CachyOS);
nvidia_drm.modeset=1,fbdev=1 - Wayland (KDE Plasma / kwin_wayland)
Repro
- Working desktop, monitor’s OSD set to DisplayPort 2.1.
systemctl reboot.- Boot completes but the monitor gets no signal.
What I see in the log — two failure sub-modes, same root cause
At nvidia-drm load, on a bad boot, enumeration comes up empty:
[drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
...~26s gap, no other GPU activity...
[drm] [nvidia-drm] [GPU ID 0x00000100] Failed to get dynamic displays during device registration.
nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
(a good boot instead says, within ~1s: Encoder with NvKmsKapiDisplay 0x00000001 already exists)
Capture 1 (Feb, driver 590.48.01): after this, kwin_wayland keeps retrying against a GPU with
no CRTCs for about a minute, and the GSP firmware then crashes:
NVRM: Xid 109 ... CTX SWITCH TIMEOUT
NVRM: Xid 119 ... Timeout after 6s of waiting for RPC response from GPU0 GSP! Expected function 10 (FREE)
NVRM: Xid 120 ... GSP task exception: supervisor timer interrupt
nvidia-modeset: WARNING: GPU:0: Failed to determine which devices were hotplugged: 0x62
nvidia-modeset: WARNING: GPU:0: Failed to allocate display resource.
This repeats for minutes; kwin_wayland / the login manager crash-loop.
Capture 2 (today, driver 610.57.04, kernel 7.2.3): same Failed to get dynamic displays /
Cannot find any crtc or sizes after the same ~26s stall — but no Xid, no GSP crash this
time. plasma-login-greeter/plasma-login-wallpaper immediately log There are no outputs - creating placeholder screen and stay there. A few minutes later, with the physical monitor never
touched, cat /sys/class/drm/card1-DP-4/status reports connected, enabled, dpms: On, and a
full EDID mode list — so the DP AUX channel does recover on its own, the driver just never
re-probes/rebinds a CRTC to it afterwards. Power-cycling the monitor at that point produced a
visible mouse cursor on an otherwise still-black screen — some partial output state gets
re-established (enough for a cursor layer) but never a full modeset.
So the actual bug looks narrower than my original report suggested: nvidia_drm gives up on
display enumeration after ~26s during device registration (likely a DP AUX/DPCD read racing the
monitor’s own link re-training, worse at UHBR13.5/DP2.1 than at HBR3/DP1.4) and never retries.
Whether that then cascades into a GSP crash seems to depend on how hard the compositor hammers it
afterwards. simpledrm is not involved — it initializes identically on every boot, good or bad,
and nvidia-drmdrmfb always takes over fb0 cleanly either way.
Workarounds
- Full power-off (not
reboot) — always works. - Setting the monitor’s OSD to DisplayPort 1.4 (HBR3) instead of 2.1 (UHBR): in my testing the
failure did not occur at DP 1.4. Same monitor, same cable, only the OSD link-rate cap changed. - Does NOT help: disabling the AMD iGPU in BIOS; forcing the compositor onto the NVIDIA node (
KWIN_DRM_DEVICES); disabling UEFI Fast Boot.
Attached
nvidia-bug-report_BAD.log.gz— captured over SSH ~1 min into the failed state (today, no Xid)nvidia-bug-report_GOOD.log.gz— same machine, healthy boot, for comparisonbadboot_kmsg.txt,badboot_full.txt,badboot_dp4.txt— full journal + DP-4 sysfs state- (from the original report, Feb, 590.48.01)
journal_gpu_focused_20min.log— has the Xid
109/119/120 GSP-crash variant
Happy to test patches / debug builds.
nvidia-bug-report_GOOD.log.gz (546.3 KB)
nvidia-bug-report_BAD.log.gz (510.4 KB)
badboot_logs.tar.gz (77.5 KB)
journal_gpu_focused_20min.log (76.7 KB)
