Intermittent USB-C DisplayPort monitor enumeration failure on GNOME Wayland (RTX 5060 Laptop GPU, driver 595.58.03)
System:
  • Laptop: Lenovo Legion 5 16IAX10
  • GPU: NVIDIA GeForce RTX 5060 Laptop GPU
  • Driver: 595.58.03
  • Kernel: 6.17.0-23-generic
  • Desktop Environment: GNOME on Wayland
  • Also tested: Cinnamon on Wayland
  • Distribution: Ubuntu 24.04-based system
  • Hybrid GPU setup (Intel + NVIDIA)
Monitor Configuration:
  • Center monitor connected directly via USB-C → DisplayPort 1.4
  • Two side monitors connected through Thunderbolt dock
  • Center monitor currently an older Sceptre 32" curved 1080p display
  • Side monitors initialize normally every boot
Issue Summary:
Intermittently after a cold boot, the center monitor connected through direct USB-C → DisplayPort is completely absent from the display topology.
When this occurs:
  • GNOME on Wayland may fail to log in properly (login loop back to GDM)
  • Cinnamon on Wayland still logs in successfully
  • The center monitor does not appear in xrandr at all
  • Only the two dock-connected side monitors appear
Example failed xrandr state:
  • eDP-1 present
  • DP-3 present
  • DP-4 present
  • center monitor completely absent
Important observation:
The center monitor is powered on and appears to be searching for signal (blinking blue standby/search LED), but Linux/NVIDIA does not enumerate the display during boot.
Recovery / Workaround:
If I:
  1. Boot into Cinnamon Wayland
  2. Unplug the center monitor cable from the laptop
  3. Wait a few seconds
  4. Plug it back in
then the monitor immediately appears and is assigned a new output (example: DP-6).
After hotplug:
  • xrandr immediately shows the monitor
  • monitor functions normally
  • GNOME on Wayland can then log in and operate correctly
  • gaming and rendering work normally afterward
This appears to indicate:
  • the hardware path itself is functional
  • the issue occurs specifically during cold-boot display enumeration / initialization
  • hotplugging forces successful re-detection and DP link negotiation
Observed behavior suggests:
  • USB-C DP Alt Mode timing issue
  • failed or delayed DisplayPort link training
  • failed or delayed EDID negotiation during boot
  • display output not created until hotplug event
Relevant observations:
  • Side monitors through the Thunderbolt dock initialize reliably
  • The direct USB-C → DP monitor path is the only failing path
  • Once detected, the monitor is stable and functions correctly
  • Games render correctly on NVIDIA GPU
  • No GPU crashes occur
  • System is otherwise stable under load
Relevant logs observed:
  • intermittent EDID read failures
  • NvKms memory allocation retry messages
  • repeated display probing during startup
Example symptoms:
  • monitor absent from xrandr until hotplug
  • GNOME Wayland login loop when monitor missing
  • hotplug consistently restores functionality
Question:
Is this a known issue involving:
  • NVIDIA Wayland initialization
  • USB-C DisplayPort Alt Mode timing
  • DP link training during boot
  • hybrid GPU display enumeration
and are there recommended debug options or logging flags that would help narrow the failure point further?
