RTX A4500 with MST Hub: Display Wall configuration
Running RHEL 8.10 with an RTX A4500 and a Tripp-Lite MST 4 port Hub (DP to 4 HDMI). The MST hub says it supports Video Wall conversion (4x1 7680x1080). How can I get nvidia-settings to treat the 4 monitors connected to the MST hub as a single display device? nvidia-settings shows I still have 4 monitors connected.
The plan is to connect 2 MST hubs to each display port connection on the RTX A4500 and have 4 monitors connected to each hub. I’m hoping to avoid the 4 display heads per GPU limitation by creating two large video walls (of 4 monitors each). So the GPU is only displaying to 2 heads.
I’ve read that I can do this with Mosaic but I can’t find any Linux support for that.
