Isaac Sim works normally in most cases, but sometimes the following RTX Loading screen appears and I have to wait for 5 minutes. After waiting for 5 minutes, it works normally. Is there any problem with this? Or can I just ignore it? The same symptoms appear when using Code.
Hi. This is normal. It is warming up your shader cache. This usually happens on first run or driver update.
Thanks^^
