I am new with PGI, I have Windows Xp 2, and cygwin installaed on my pc,
I have installed PGI 7.1-2 too,
and now i want to use PGI 7.1-2 from cygwin to compile my Program Lmtart_4review ( fortran program).
So please can anyone from here help me to do this,
you can contact me at: benkhettoua@yahoo.com
Thank you very much for your assistance
When you install PGI compilers, it should create a shortcut on your desktop called “PGI Workstation” icon. Click on that it will launch a Cygwin bash shell command windows with pre-initialized environment setttings.
I know that I have a cygwin bash shell command but what i want is to use fortran from PGI to make a makefile in the lmtart_4review ( fortran program) situated in my cygwin part,.
The icon is called “PGI Workstation” and it should reside on your desktop.
It should have a mountain covered with snow on top with blue background.
Click on that icon, it should launch cygwin bash shell, from there you can type: make (if you have makefile created), or just type pgf90 yourprogram.f, etc.
If it is not there, then you probably chose not to create shortcut for PGI Workstation on your desktop when you install PGI Workstation.
In case you don’t have that shortcut, you can go to the installed directory and start up a pgi_env.bat and then start your bash shell.
For example, assuming it is 32-bit, and install in C drive:
% cd “C:\PROGRA~1\PGI\win32\7.1-2”
% pgi_env.bat
% call “C:\cygwin\bin\sh.exe”
Now, you should be able to do makefile with PGI compilers.
