I need to run caffeMNIST app on desktop GPU as the app is not supported on Jetson GPU as clarified by NVIDA previously. Since the apps can be run using deepstream app -c command as mentioned in the manuals and online, in absence of deepstream on desktop, how can I successfully run the app?
Any lead would be appreciated.
Yes I could successfully run test1. CaffeMNIST is one of the reference app of NVIDIA for handwritten digits recognition use case. Please refer the link below
As suggested by NVIDIA on another thread, this is only supported on desktop GPU so I am trying to run it on that. I have installed desktop version of DS4. Would let you know in case I face any issue further.
I installed all the pre-requisits including CUDA and TRT for DS4 installation on Desktop GPU using TAR file.
While running config file source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8 using command deepstream-app -c I am getting following error:
Error: Could not get cuda device count (cudaErrorNoDevice)
Failed to parse group property
** ERROR: <gst_nvinfer_parse_config_file:943>: failed
Unable to set device in gst_nvstreammux_change_state
** ERROR: <main:651>: Failed to set pipeline to PAUSED
Quitting
Can it be a GPU issue? My desktop has Intel VGA controller and NVIDIA 3D controller active, however, if I try to switch from Intel to NVIDIA it’s still showing Intel as active graphics card.
