I am trying to run unet segmentation model , I have an etlt file , through which I am running my app , I pass in an image as the argument, the program runs fine it creates a engine model file as well , and at the end it says “handling EOS for source-0”
, then “end of stream” , there is no error anywhere , but the output image is not saved in the output directory , now instead of image if I pass a video it says error: out of memory or failing drivers.
Can you provide the command line to reproduce this issue? and what’s the Jetpack version in use? Please provide complete information as applicable to your setup.
• DeepStream Version
• TensorRT Version
• The pipeline being used
Hardware Platform : Xavier
Deepstream Version : 6.2
Jetpack Version : NVIDIA Jetson Xavier NX Developer Kit - Jetpack 5.1.1 [L4T 35.3.1]
TensorRT version : Tensorrt version shown in the images below
The command I ran :
python3 deepstream_segmentation.py dstest_segmentation_config_industrial.txt te.jpg output
output :
Using Tao Unet model exported in .etlt , running the above command produced a engine model.
Deepstream App I am running : deepstream_python_apps/apps/deepstream-segmentation at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
Modified Config File:
[property]
gpu-id=0
#int8-calib-file=cal.bin
labelfile-path=labels.txt
tlt-encoded-model=model_isbi.etlt
model-engine-file=model_isbi.etlt_b1_gpu0_fp32.engine
uff-input-order=0
uff-input-blob-name=input_1
batch-size=1
network-mode=0
interval=0
gie-unique-id=1
#parse-bbox-func-name=NvDsInferParseCustomSSD
#custom-lib-path=nvdsinfer_custom_impl_ssd/libnvdsinfer_custom_impl_ssd.so
#scaling-filter=0
#scaling-compute-hw=0
net-scale-factor=0.00784313725490196
offsets=127.5
infer-dims=1;320;320
tlt-model-key=nvidia_tlt
network-type=100
num-detected-classes=2
model-color-format=2
maintain-aspect-ratio=0
output-tensor-meta=1
segmentation-threshold=0.0
output-blob-names=argmax_1
segmentation-output-order=1
[class-attrs-all]
pre-cluster-threshold=0.5
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
#[class-attrs-2]
#threshold=0.6
#roi-top-offset=20
#roi-bottom-offset=10
#detected-min-w=40
#detected-min-h=40
#detected-max-w=400
#detected-max-h=800
The issue is that no output frames are written
Please Reply as soon as you can !
1.This demo cannot support video, it just support jpeg image. If you want to support video, you need to customize it by yourself.
2.This demo cannot support using Gstreamer to save file. You can add some log to debug if the seg_src_pad_buffer_probe has been called normally.
What is the use of the output folder argument mentioned in the readme then ? The deepstream_segmentation.py has opencv code in there to save frames , does that not work as well ? Is there any other git repo that uses the segmentation model for video processing ?
Sorry, I mean it use the opencv to save the picture not Gstreamer filesink plugin. Could you run our demo with our model and config file first to check if it can save the jpeg picture?
So it should save the segmented image right ?
Yes. I run our demo with the command below, it generates the 0.jpg in the output path.
sudo python3 deepstream_segmentation.py dstest_segmentation_config_industrial.txt ../../../../samples/streams/sample_industrial.jpg ./output
